Door Lock Light - Washer won't work
Kind Readers,
I have a Frigidaire GLTF1670AS front load washer. The "Door Lock" light comes on, but the washer won’t work at all. No water, no agitate, no spin. Anyone have any ideas as to what to check?
Thanks in advance.
  • DB
Thanks. Finally found the service manual on-line. Troubleshooting guide in the service manual suggests the door lock assembly should be replaced. That’s what I’ll do. Thanks!
  • DB
where did you find the service manual online? I have the exact same problem.
You should find the service sheet behind the front panel but, you will need a meter to check things. I had one that had a connector came loose.
