Door not self closing
Right side door no longer self closing. Also makes grinding noise when openning wide at times. Illustrations on web show cams used. Mine does not have any. Top hinge has post about 2 in long and groved. Fits into collar at top of door. Suspect door contains spring or some such. Is a replacement available?
Thanks.
When the F3 error code is displayed on your oven, this indicates that there is a fault with the oven temperature sensor. There are a few parts that could be causing the fault. These include the wire harness, control board or the oven temperature sensor itself.
