door is stuck in lock condition…f22 fault on display;;;;;is there anyway to open without breaking open thanks
— Begin quote from drdavid;412088
Dave , there are two methods of manually unlocking the loading door latch assembly.
We’re sending both, just in case.
Good Luck,
#1
[FONT=Swiss721BT-Heavy][SIZE=2][FONT=Swiss721BT-Heavy][SIZE=2][LEFT]Manually Unlocking the Door Lock System[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]1. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Unplug washer or disconnect power.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]2. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Remove the lower kick panel.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]3. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Reach up along the inside of the front and locate the
bottom of the door switch/lock unit.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]4. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Located on the bottom of the door switch/lock unit is a
tear-drop shaped tab.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1][LEFT]5. [/SIZE][/SIZE][/FONT][FONT=Swiss721BT-Roman][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]Gently pull the tab down about a ¼" or until a click is
heard.[/LEFT]
[/SIZE][/FONT][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Black][SIZE=1]6. [/SIZE][/SIZE][/FONT][SIZE=1][FONT=Swiss721BT-Roman][SIZE=1]The door may be opened.[/SIZE][/SIZE][/FONT]
#2
[LEFT][COLOR=#000000][SIZE=3]Manually Unlocking the Door Lock System[/SIZE]
[FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]1. [/SIZE][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Unplug washer or disconnect power.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]2. [/SIZE][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Remove the top washer panel.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]3. [/SIZE][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Reach down along the inside of the front (between tub and CCU) and locate the top of the door switch/lock assembly.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]4. [/SIZE][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Located on the top of the door switch/lock assembly is a ring-shaped tab.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]5. [/SIZE][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Gently pull the tab upward about ¼" or until a click is heard.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]6. [/SIZE][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]The door may be opened.[/SIZE][/FONT]
[/COLOR][/LEFT]
