just talked to someone and they ask if i replace both cams on the hinge assembly. there should be one on the hinge itself and one on the door i replaced the one on door but not the one on fridge itself could you tell me what part number that i need just could not find part that i need. When i replace the one on door did not help with noise still pops when open or closing. frs26hf5a
Can you give us the full model number please? Thanks.
frs26hf5ab0
my model number frs26hf5ab0
Thanks here is the part number you asked about. [part]AP2116504[/part]
thanks for all your help. hope this does the trick and there is no more popping noise
