Double Oven Problem
Hello.
My upper oven does not heat properly. The broiler works fine but the baking element is around 200@350. I replaced the element and found one of the pins arced off the wire. I did a resistance check on the temp sensor and it is 1.1k ohms. Is there anything else left to try or is the brain fried?
Thank you,
Al
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=rbd305pdq12
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208301761.pdf
I assume that the bake element is still not heating up.
I would double check the wiring from the control board to the bake element.
If OK then odds are high that it is the board.
Probably blew the bake relay contacts up when it arced.
Looks like I am out a control box.
Thank you for taking the time to answer my email and Happy Holidays.
Al
