The bottom oven came on by its self and I had to turn the breaker off to shut it down. I turned the breaker back on and soon the bottom oven came back on. The top oven worked as normal. I turned the breaker back off and now the breaker trips when I attempt to turn the breaker back on. It would be helpful if I knew where to start looking.
Most likely the problem is a bad (shorted) control board.
- The control board AP3767567
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264810
Insert a flat screwdriver between the plug and the control board and carefully pry the plug up.
