Whirlpool Double Oven not working
Hi I need help please. I was out of town two weeks ago and when we got home the double ovens would not turn on, control panel display is blank, oven just beeps when I pushed any keys or try to turn it on but nothing comes up on display. There is power because the inside lights come on when you open the door and/or press the button on the control panel display. The main breaker was not tripped.
Based on your experience, what could be the most likely cause; the thermal overload, the thermal fuse or the electronic control boards??? Any ideas?
Hi.
Try to reset the circuit breakers all the way off, give it a few minutes, and then turn it back on. If that would not help the main control board should be replaced.
The main control board AP5801413
Be careful not touching any of the parts at the new control board because your body’s static electricity may damage a brand new control!
Keep in mind that you may return back to APP.com ANY parts that you don’t need without ANY questions asked within one year from purchasing the part.
Here are the breakdown diagrams and parts list fro your oven
[MODEL]GBD307PRS01[/MODEL]
Good luck. Please keep us posted of the outcome of the repair.
Thank you.
Simon.
Hi Simon,
Thank you for your quick response and help. I tried resetting the circuit breaker with no luck. I am going to get a new main control board but before I remove the old control board how can I test the control board using a multi-meter to make sure the control board is faulty.
Thanks again
Ed
Hi.
Unfortunately you can’t check the control board in this case.
Thanks.
Simon.
