Double Oven only beeps
Hello,
I have looked through several posts about the issue I am having with my double oven and am unclear as to the proper fix. The other day the oven was working fine, then a day later the display is dark and when you hit the "upper oven" button and then start it makes sequential beeps. The light button turns on the light and it appears the timer works, though i cannot see anything. How can I determine if the control board is bad (part 8303883) or if it is a thermal fuse?
thanks
Hi.
Based on the information you provided the control board is bad
W10340941
Here are the breakdown diagrams and http://www.appliancepartspros.com/control-panel-parts-for-whirlpool-gbd307prb01.html
Post the results.
Simon.
Hello, I am trying to get to the control board and cannot seem to get to it, any hints?
I removed the trim from either side fo the oven and removed the screws from part 1 of the control panel diagram (these screws were not going into anything because I do not see a part 7 on my oven). Are there tabs or something that need to be pushed in to get the front panel to come off?
thanks
