6 yr old washer with no prior issues except for I replaced the drain pump 2 years ago. A few days ago shortly after starting a load to wash the machine indicated code NF (No Fill) . I’ve checked the obvious things listed on Samsung trouble shooting site such as making sure water inlet screens are clean, using traditional steel braided hoses (No flood safe hoses ). I Have plenty of water pressure entering the washer tub but I notice as soon as I power the washer on the drain pump is running continuously and if you start a wash cycle the pump is pumping the water out thus causing the NF code!.Any thoughts?
model is wf206bnw/xaa
