Washer Pump Stays on during fill.
Had the pump mount fail on me so replaced it with relocation kit. Bought used from someone on the cheap because I hoped I could fix it. Replace engines in cars and fabricate all kind of crazy shit so why couldn’t I do this?
It didn’t work before, but now does. Turns on okay, pumps water in okay, however WHILE its filling water in through the valves, the pump is pumping all the water out (when it really shouldn’t even be on). After a few minutes of wasting my water, it gives me the dF error (obviously didn’t fill).
I’ve checked the filters in the fill-valves for debris and turned up none.
I’ve checked that my hoses are not flood-safe, and are not kinked, and clear of debris.
I’ve made sure the washer is level.
I’ve made sure that the drain hose is straight vertical, and runs a 180 degrees into the drain pipe (with only 4 inches in the drain)
My guess is theres some sort of water sensor or something thats allowing the tub to drain, but even so, why is the pump on at all? I’ve about had it with this thing and can’t afford to buy a new set and keep buying parts for this. Any ideas guys?
