drier will not run
Drier was running and wife opened the door to remove an item. The drier will not start. It is an electric drier and the power is good, door switch is good. What are the possible causes?
Here are your parts includes a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE3000AYW
You will see 2 thermal fuses (Item 11 in Section 5 and Item 10 in Section 6), odds are one of them is blown.
