Drive Block Stuck in Basket
Drive Block wont go on Transmission shaft New drive block, compares to the old one, but is very hard to get on the shaft, I put petroleum jelly, on but that didn’t help.got it down about two inches and it was so tight that i took it back off. The old one slips right down into place. Part # FSP 389140 It took ten min. to get it back off. What do you recommend??
Wrong subject above, I solved that one
It should fit tight, but not too tight. I recommend you return it to the seller and get a replacement (freebie)
