drum out of line-staining clothes
I am noticing black marks and some tiny holes on my clothes after dry cycle, where clothes appear to be caught on something inside dryer. I see a gap between rim on back of dryer. How do you re-align this?
The part number for the front and rear tumbler seals (they are the same) is [AP3970861](http://www.appliancepartspros.com/partsearch/ctrfs.aspx?part_id=286710&&model_id=27373&diagram_id=801179"]AP286710[/URL]
You also need to order the adhesive to attach them. The part number for the adhesive is [URL="http://www.appliancepartspros.com/part_details.aspx?part_id=3970861)
Here are the break down diagrams for the Maytag dryer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=801179&&model_id=27373
The model number on my Maytag is LDE7304ACE. In addition to replacing the felt drum seals, I replaced the drum wheels - one of which had fallen off the shaft. We used part no. 413820 - is this the rights seals for the front and back, but took them out when the drum was not turning and put in the old ones. Drum still won’t turn though. Thanks for your help.
