Dryer Does Not Turn Off on its Own
My electric dryer runs fine except that it will not turn off when I use the timer settings or the autodry settings. I have to manually open the door to turn the dryer off. Is there a sensor or timer that I need to replace?
From all the repair sites, without getting out an ohm meter, it’s the timer. My dryer (Maytag) is doing the same thing: dries the clothes but doesn’t end a cycle on its own (auto or timed setting). My part is $58 and change…it’s a simple remove and replace part only a few screws and a number small clip electrical leads away from homeowner replacement–Phillips head screw driver and needle nose pliers…of course disconnect your power before any maintenance. I’m ordering online…
dryer timer won’t advance and temperature is on hot only
— Begin quote from 870poorman;645550
[SIZE=5][FONT=Comic Sans MS][COLOR=DarkSlateGray]
What kind of dryer is it?[/COLOR][/FONT]
[/SIZE]:confused:
