Dryer will not start. The light does come on in the dryer. Have checked the door switch and I think the thermal fuse. Nothing has checked bad. (ohm good). What else can I check to see why this will not work before checking the motor.
— Begin quote from brsummers;264704
…I think the thermal fuse…
Make sure you checked the real thermal fuse (#6 on the diagram) for continuity. The normal reading should be close to 0 Ohms.
- The thermal fuse AP4048636
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194
Checked this fuse and there was continuity. What is the next thing I check if this part is good?
— Begin quote from brsummers;264817
This is your wiring diagram. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194&diagram_id=1340495#d1340495
I’d check the timer. It could be your motor, it could be a broken wire, it could be missing voltage, or it could be a contact burnt off inside the timer.
