dryer dont lit
The ignitor lights. the gas dont pick up, after about 20-30 sec the ignitor lights again but the gas still dont pick up. So the dryer dont work. What is most likely the problem?
— Begin quote from jacksa;159081
the dryer dosnt pick up the gas, so the dryer dosnt get warm, the ignitor does work
— Begin quote from Gene;159125
Assuming there is gas to the dryer and gas shut off valve is open, most likely the problem is a bad gas valve coils (13 & #14 on the Replacement parts for MAYTAG SG1000 Stacked Laundry - Gas | AppliancePartsPros.com.
  • The coil kit [part]AP3094251[/part]
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=27854)
Thanks! so I shoud buy only part # AP3094251? What about parts 13 and 14? you wrote?
This is the kit which included both coils.
— Begin quote from Gene;159175
Hi again.
It might sound like a silly question…why do I need a kit ot 2 coils? I see in the back only 1 black coil? also, I see im ******** part # 279834 of Maytag, for $5.95 plus s/h is it the same as Whirpool AP3094251 for $14.95 plus s/h. But each part 13 or 14 as you mentioned is $23.95 plus s/h, I’m confused.
Which part should I buy? how many coils do I have to replace? where are they?Thanks!
