Dryer gets too hot
My dryer gets very hot on all but the lowest heat setting (Delicates); at that setting, you can just touch it and it is bearable. I just cleaned out the vent tubes when I replaced the rear bearing and they didn’t have much of a lining of lint at all. To note: it was getting too hot before I opened it up to replace the bearing.
I suspect a thermostat but this website’s parts pages show two are available: AP3210790 (Thermostat-cont-elec w/m.S.) and AP2131477 (thermostat).
Which one should be replaced to fix the problem? If not a thermostat, then what?
