Drum is rotating I can see the flame underneath the dryer. After 2 hours of dry time (small load) the timer has not advance. Any ideas and/or can someone guide to an old post on this forum. Thanks.:eek:
First thing is to be sure that the dryer vents to the outside of the house are clear. The air should be coming out pretty good. If so, I would replace the coils on the gas valve. That is usually the likely culprit. You could ohm them out, but they still could be bad. Tom http://www.applianceeducator.com/parts.htm
[SIZE=3]I tried the cheaper fix first cleaned the vent from the dryer to the outside vent and walla we’re back to a complete drying cycle, two thumbs up. Need to replace the lint trap has a nice big rip in it. Now that you solved this problem I just finished gutting the kitchen think you can help me with the plumbing nightmare I just ran in to, just kidding. Great forum thanks much.[/SIZE]
[SIZE=3]John [/SIZE]
Go Job!!! Glad to help!! Have a Happy Thanksgiving!! Tom http://www.applianceeducator.com
