Dryer heating motor wont start
Dryer 13 months old Heat is coming on but motor wont start. Checked power coming in to the dryer all ok. checked power to the motor power there but when you push the start button it wont start. heat does and heat wont go off when the door opens. What is keeping the motor from starting ? Motor makes no noise,belt fine took belt off still motor wont come on can spin motor by hand freely. tested door switch with ohm meter shows good.
Per the schematic, pins 4& 5 should be the wires to run the motor, just check. Pull dryer apart and stick 115 volts to these pins, if motor fails to spin, you probably have a bad centrifical switch. You can take the switch apart or order a new one.
