dryer is hot in the back
I recently had my upper and lower felt replace on my dryer, the grounding
wire had dismember from the terminal block. instead of replacing the
terminal block, the company that I had to repair my dryer, rerouted the grounding wire where it is no long going through the terminal block. Now, when I used my dryer it is getting extremely hot to the touch and it has a burnt smell in the area where he worked on at the back of my dryer.
what has he done to my dryer and can it be repaired?
