dryer makes continuous loud squealing noise
:frowning: [SIZE=3]Today the dryer will not even start. Do we need a new drive motor?[/SIZE]
The first thing you may want to do is to take the dryer apart and check the front glides and pads (13 & #14 on the [B]diagram and rear drum support rollers (#18 on the diagram).
Check the blower wheel (#8 on the [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=19441&diagram_id=665160)) and clean the dryer exhaust line all the way through the vent outlet.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=19441
— Begin quote from Gene;254895
The first thing you may want to do is to take the dryer apart and check the front glides and pads (13 & #14 on the [B]Replacement parts for AMANA LEA30AW Dryer - Ele | AppliancePartsPros.com and rear drum support rollers (#18 on the diagram).
Check the blower wheel (#8 on the diagram) and clean the dryer exhaust line all the way through the vent outlet.
  • The glide (have to order two) [part]AP4046795[/part]
  • The felt pad (have to order two) [part]AP4054015[/part]
  • The roller (have to order two) [part]AP4046756[/part]
Here are the breakdown diagrams and [URL="http://www.appliancepartspros.com/partsearch/model.aspx?model_id=19441)
Gene the dryer will not even start today! Do we need to replace the drive motor?
