Replaced the heat element to start, worked great for 3 loads. Then no heat, everything works but no heat. Element test show continuity, as does the resistor attached to the element metal shell. everything has been removed and cleaned first time around, no blockages. ?? help
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=AEQ6000ES2
Here is the units tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134682200ts_wd_EFS.pdf
First check that the power is OK.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
