Just replaced the limiter fuse and heater assembly/thermostat but still not heating up. Dryer runs okay but no heat. I need help. Thank you
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=AEQ8700FE0
Here is the tech sheet.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134682200ts_wd_EFS.pdf
Did you check the parts to determine that they were bad before replacing them or did you just replace them?
Have you checked the power.
The heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
