frigidaire dryer won't heat up
my dryer won’t heat up… comes up with the code ad while in the cycle…did the system reset and it gave me the error code re5…any ideas???
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=aeq7000ces1
Here is the tech sheet
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134682200ts_wd_EFS.pdf
I cannot find an error code "re5" are you sure it was not reS, see the tech sheet.
Try running the diagnostics to see if that gives any additional info.
looks like it is a heating problem so I would check the power to the unit first. The motor and the control board run off of half the line (120 volts) but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If the power is OK.
Check the heater, the hi-limit thermostat and the thermistor for resistance.
