Hi, I had a backed up lint trap, cleaned it out and now the dryer has no heat and runs then shows AD. I did the the error codes test and these are the codes I got.
The "ad" in the display simply means it is in an Auto Dry cycle. I suspect you have an open thermal fuse if the vent was restricted. Do you have a meter to test continuity with?
I doubt it is the thermal fuse as it looks like if the thermal fuse blew the motor would not run on this unit.
I would start by checking the power to the unit. the control board and motor run off of 120 volts but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
If the power is OK then unplug the unit and check the heating coil and then the hi-limit thermostat with a meter. Note that if the high limit is blown be sure to check that the heating element is not grounded. Also check the thermistor just to be sure that it is OK.
I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long.
Always remove power from the machine otherwise you could blow your meter.
Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
Thanks,I replaced heating element, it was burnt and broken, but still no heat and dryer runs and then says add after running for a bit. I guess I need a tester to test the other parts listed.
The L1 side of the voltage to the element comes from the control, through the high limit thermostat and to the heater. The L2 side comes from the motor. So, if you have proper power supply voltage, one of those three components is likely faulty. You may have luck turning the breaker totally off then back on as when the element shorted, it may have tripped the L2 side of the supply. If still no heat, you will need a meter to test voltage with.
I have tested the power from the wall it is what is was supposed to be, tested the thermal fuse and the high limit thermostat, even heated it to see if it clicked off at the temperature listed and it does. The last thing I haven’t checked is the thermistor. and I don’t know if it is worth replacing the Electronic control if it happens to be that . :mad:
On the back of the main control is a large relay that has a large red and a large black wire connected to it. Remove the black wire and tape it off. Then, start the dryer in a heat cycle and test from the terminal the black wire was on to ground, looking for 120 VAC. If you do not read that voltage, the control is indeed faulty. If that is the case, the control is available at the link below. Let me know what you find.
