Dryer no power, no lights
Hi everyone,
I have a electric Magic Chef dryer that all of a sudden has no power. Light does not come on and seems dead. It Does make a clicking sound when I turn the knob though. Circuits seem fine. Any suggestions would be appreciated.
A model number may hyelp others help you.
http://www.appliancepartspros.com/modelnumber_locator.aspx
Since the drum light no longer works I would start by checking the power.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
