Dryer will not turn on
I have power to chord. Tested 2 fuses and door switch. Thought it was motor? Still nothing. replaced timer, nothing. Now what? Is it possible that door switch or fuses test good but are bad? Yes I hold door switch closed and push on button but nothing happens? Any suggestions short of ordering the door switch and 2 fuses? Its an electric dryer.
You check the start button for voltage and continuity?
I believe its part of the timer that i replaced
The timer is the start button and its brand new
