Electric dryer not heating. Removed toepanel and checked leads to thermal switches. Thermal switches showed less than .5 ohms. Replaced topanel and dryer worked. A couple weeks later stopped heating again. Replaced thermal switches, which still tested out okay. Dryer worked for about 2 weeks and stopped heating. Removed and replaced toepanel. Dryer is working again. There doesn’t seem to be any switches connected to the toepanel. I do lift the front of the unit a couple inches to get easier access to the screws holding the toepanel. Any opinions on what is happening. Thanks
Hi.
You should check the heating element and connections including the power cord, and wire harness and plugs at the control board.
Simon.
Here are the breakdown diagrams and http://www.appliancepartspros.com/02-cabinet-parts-parts-for-maytag-mede500vw1.html
