Dryer not heating after replacing element
I just replaced the heating element on the dryer and it does not heat up the element. Is there something that controls te electricity to the element that can be replaced. This dryer is about 2 years old and is barely used.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MED5800TW0
Did you check the heating element with meter or see that it was broken before replacing it?
OR
Did you assume it to be the most likely cause and so re[placed it?
Yes; there are a number of things.
Main thermostat (Item 8 in Section 3)
Thermal cut-off (fuse) (Item 9 in Section 3). Note: it includes a hi-limit thermostat. The hi-limit should have regulated the temperature so the thermal cut-off did not blow so it is assumed that it also did not function correctly. If you had a grounded element then the thermostat could not regulate the temperature and that is why the thermal cut-off blew.
There are other things but the above are the most common.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heater requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
Be very careful as 240 volts is lethal!!!
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
