I am having trouble with my dryer. It won’t dry the clothes, not getting any heat. I just replaced the heating element assembly and thermostat sensor but I am still not getting dry clothes.
Does anyone have any answers???
Tom
Tom
Here are your parts includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE5500AYW
Did you replace the parts in an attempt to fix the no heat problem and did not do any troubleshooting but felt they were the most likely cause?
Also I am not sure what thermostat you replaced.
You have 2 thermostats in the heater circuit and also a thermistor (sensor) connected to the control board.
First I would check the power.
The heater requires the full 240 volts while the control, motor etc. only require 120 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
