NO HEAT in Dryer
Dryer works great except NO HEAT. The inside light is not blown (I checked the bulb in another appliance) yet does not work. Could that help in solving the heating problem. The dryer is not clogged and very clean. Please help.
Here are your parts includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE7400AYW
Sounds like you may have a power problem.
You will notice in the wiring diagram that the motor and timer run off of L1 to Neutral (120 volts).
But the heater requires the full 240 volts (L1 to L2). Also on this unit the light runs off of L2 to Neutral (120 volts)
So my guess would be that you have lost the l2 side of the line.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
