issues with maytag dryer
replaced element checked thermastats all have continuity what else could be wrong runs but doesn’t heat:cool:
Here are your parts, includes a wiring diagram.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mde4000ayw
Have you checked the power to the unit.
The timer and motor run off one side of the line (120 volts) but the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
