maytag Electric dryer
Dry runs but does not heat. No obstruction. Had broken wire from one of the heating coil. Repaired, still no heat.
Presume that a fuse is blown but find none.
Gerry
Hi,
Check to make sure you have 240 volts to the dryer.
Video: How to check voltage at cord on a Maytag electric dryer.
gws001
I would check the terminal block on the back of the dryer (were the power cord is connected to the dryer) for burned wires. Also it should be 240V between two hot wires besides 120V between each hot to Neutral. Make sure you have 240V.
It is back together and working.
THANK YOU**********************
