Dryer will not heat/replaced heating assembly-still no heat/thinking may be thermostat–any ideas?
Could be a number of things but the first thing to check is the power.
Otherwise you could waste hours ripping the unit apart and checking things without any luck.
The motor, light etc. run off of 120 but the heating coil requires 240.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next would be to unplug the unit and check the thermostats.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
