My dryer won’t heat anymore. Everything runs fine but it won’t heat on any setting. Please advise. Thank you
A model number may help others help you.
First check the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
The motor etc. usually requires 120 volts while the heating element needs the full240.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Next unplug the unit and check the heating coil with a meter, most are in the 10 to 12 ohm range.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
- When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
