Dryer
Everything seems to be working on my dryer except for there is no heat. It tumbles, the blower is working, and the timer seems to be working. I have replaced the heating element, but the dryer is still not heating up. Does anybody know what else could be causing this problem?
Here are your parts.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=rex4635eq2
See the attachment for a wiring diagram. I could not find one for an EQ2 so the diagram is for an EQ0 but odds are good that yours is the same.
Start by checking the power, the heating coil requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Next check the heating coil, the hi-limit thermostat and the thermal cut-off.
Heating coil should be 8 to 12 ohms. Both the other parts should be 0 ohms.
If the thermal cut-off is blown get back to us before replacing it as there are other things to check before replacing it.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
