My dryer will not heat. I need to know what does the heating element looks like when I open take the back off.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=REX6634RQ1
See Item 17 in the Bulkhead section
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576793.pdf
I am assuming that the drum rotates and you just do not get heat!!
NOTE: Be sure to unplug the unit when opening it up and working on it, 240 volts is lethal!!!
Does the timer advance in timed dry mode?
Both the timer and the heater require 240 volts.
If not try turning the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker. Better yet measure it with a meter.
If the heater measures OK (10 ohms approximately) the next possible cause is the thermal cutout Item 6 in the Bulkhead section (0 ohms at room temperature)
If the thermal cutoff is blown be sure to give the interior including the blower wheel a good cleaning. Also clean/check your vent system.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
I’m having a problem with my washing machine reaching it’s full spin cycle to get ride of the extra water, it only works on small loads? Almost seems as if the motor might be going out?
Please share your thoughts…
Thanks,
Dave
Dave,
Remove the front panel and check the belts.
Does the motor make any unusual noise?
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=15366
