Dryer won't heat
I don’t get ant heat from my dryer anymore. Any help as to what is the problem. Heating element?Fuses?Thermostat?
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133202
See the attachment for the wiring diagram
Could be any of these plus a couple other things.
Note: the thermal fuse for the heater is Item 9 in Section 3 (thermal cut-off).
If it is blown then there are other things you should check before replacing it.
The one on the blower is for the motor.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker and the heater circuit requires the full 240 volts.
L1 to L2 should be 240 volts
If OK
If OK
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
It is usually either the thermal cutt of switch, or the element. Unplug the dryer, and take the big back panel off. The element is on the right bottom. There is a few 1/4 inch screws to remove it, on each side of the element housing. The thermal limit switch is on the top left side of the heater housing. It has 2 wires coming to it. If you have an ohm meter, pull the 2 wires off of the thermal limit switch, and check for continuity. If you have any reading it is good. Do the same to the element. Tom http://www.applianceeducator.com/parts.htm
