dryer works but no heat
my dryer works but has no heat what is wrong
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5134315
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%208576793.pdf
Could be a number of things.
First check that you have 240 volts at the plug.
Flip the breaker off/on slowly a couple times, sometimes you can loose half the line without tripping the breaker. Better yet check it with a meter.
On this unit the timer uses 240 volts so if the timer advances in timed dry mode you have the 240.
Next would be the thermal fuse or the heater itself.
Note the thermal fuse for the heater is Item 6 in the Bulkhead Parts section.
If the fuse is blown clean the interior, including the blower wheel.
Also clean and check the vent system, this is the most common cause of the fuse blowing.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
