does not heat and timer does not move
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=rex6634rq0
Here is the wiring diagram, see attachment.
First thing to check is the power. The motor uses half the line (120 volts) while the heating coil requires then full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next check the heating coil, should ba about 10 ohms.
The4n check the thermostats and thermal cut-off, all should be 0 ohms.
If the thermal cut-off is blwn there are other things you should check before replacing it.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
Unplug the dryer, and take the big back panel off. Then on the right hand side, is the heater housing. It will either be the element, or the thermal fuse. The thermal fuse is located on the top left side of the heater housing. To take the element out if you need. There are two 1/4 inch screws to remove, one on the left of the housing, about 6 inches from the bottom of the housing, and one on the right. Take the wires off the element, and slide in right out. Good Luck Tom http://www.applianceeducator.com
