Dryer Will Not Heat
My dryer will not heat. I checked the jumper wire and it is ok. What is the most common problem? Heating Element, Hi Lo Limit Thermostat or Thermal Fuse?
Randy
Here are your parts includes a wiring diagram
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=MDE8400AYW
Here is a manual, note it is for similar models not this specific model.
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Not sure what you mean by jumper wire.
Heating Element - this would be at the top of the list
Hi Lo Limit Thermostat - also a possibility along with the cycling thermostat.
Thermal Fuse - not possible as the fuses in this unit kill power to the motor
First try flipping the breaker off/on slowly a couple times, sometimes it can loose half the line without actually tripping the breaker and the heater requires the full 240 volts. Better yet measure it at the plug
L1 to L2 should be 240 volts
Also unplug the unit and check the wiring at the unit’s terminal block to ensure a wire has not burned off.
Next unplug the unit and check the heating coil.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
