Heating element was burned out so I replaced with new element as well as new thermostat. Dryer turns on but element does not heat up. What else should be checked?
— Begin quote from WW47;247276
Does your house have fuses or circuit breakers that power the dryer? Do you have 240 volts to the dryer?
You see a dryer can run on 120 volts, but not heat. So you might be missing half your voltage.
Or you could have a bad timer or burnt off wire or an open cycling thermostat.
