My dryer turns on and runs but does not heat up on any setting. Thermostat, element, fuse, wiring? Easiest and cheapest way to find out which needs to be replaced?
You need to check all those parts, you just mentioned, with an ohm meter. It has to be one of the three you mentioned. Tom http://www.applianceeducator.com
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5141051
The first thing to check is the power.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Once you know that the power is good then you can check the heating coil and thermostats with the unit unplugged using resistance on the meter.
