my whirlpool dryer stop heating, so I checked the element. I noticed that the thermostat attached to the element was burned out. I replaced the heating element and the thermostat that is attached to the heating element but still no heat. what should I check next to find out why I’m not getting heat or what should I check to find out what caused the thermostat to burn out.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LER4634EQ1
I would start by checking the power.
The heating element requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
Was it the thermal cut-off on the heater assembly that you replaced or just the hi-limit thermostat or both?
