Replaced heating element and thermostat, checked continuity and there is still no heat! Breakers are good and so is thermal fuze.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=LER4634JQ0
How do you know that the power is good?
Did you measure it with a meter?
If not you should. The motor runs off of 120 volts but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the wall receptacle
L1 to L2 should be 240 volts
If OK
If OK
Did you check the thermal cutoff and the hi-limit thermostat on the heater case?
