Whirlpool
Dryer won’t heat, ordered element and replaced and dryer still won’t heat. Should we replace the thermostat and if so which one and do you know the part #.
Thank You!
Renee
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ler4634bq1
Here is the wiring diagram
http://www.servicematters.com/docs/wiring/Wiring%20Sheet%20-%203401728.pdf
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next check the thermal fuse and thermostats with a meter.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
