my whirlpool dryer has no heat
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5136097
First thing to check is the power. The motor etc requires 120 volts but the heater requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
If OK then unplug the unit and check the heater and the thermostats with a meter using resistance.
If the heater’s thermal cut-off (Item 6 in Section 3) is blown get back to us as there are other things you should check before replacing it.
- Always remove power from the machine otherwise you could blow your meter.
- Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
- When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
