no heat in dryer
unsure how old it was a free item
the dryer is just not hot only cool air
how do you know if it is element or thermostat?
Here is the parts breakdown.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=ler4634eq0
Here is the wiring diagram, see attachment.
First you have to find out if the powers is OK.
The motor etc uses 120 volts while the coil requires the full 240.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Once you know that the power is good you can unplug the unit and check the parts with meter.
If the thermal cut-off is blown then are are other things that have to be checked before you replace it.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
