My electric dry work but does not have any heat meaning it just blow cold air instead of hot air. Any idea would be appreciated.
Thanks,
lucky_Me
Thanks,
lucky_Me
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=245438
First check the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
L1 to L2 should be 240 volts
If OK
If OK
Next I would check the heating coil (Item 9 in Section 3) should be around 10 ohms.
Then the thermal fuse (Thermal cutoff) ( Item 9 in Section 3) should be 0 ohms.
If this is blown then there are other things you should check as tyou have to find out why it blew.
