electric dryer
:frowning: :confused: my older elec whirlpool dryer quit heating, but still blows/runs fine. i cleaned vent out, what could be the problem? good old set and don’t want new one. :slight_smile: :confused:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=245438
Could be a number of things.
First I would start with the power.
Next would be the heating element. Usually 8 to 12 ohms.
Then the thermal cut-off. Should be 0 ohms.
Then the hi-limit or the cycling thermostat. Both should be 0 ohms.
Then the timer contact.
And finally the motor’s centrifugal switch. Cannot really check this so if everything else is OK then you assume it is this switch.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
Do this with the heater off and on.
  1. Always remove power from the machine otherwise you could blow your meter.
  2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path.
  3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale’s dynamic range.
  4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
